wan28201gb/28 Bosch washing machine, how do I remove the inner door frame?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum wan28201gb/28 Bosch washing machine, how do I remove the inner door frame?
  • #101325
    Dcll
    wan28201gb/28 https://shop.ukwhitegoods.co.uk/20001372-washing-machine-inner-door-frame
    Door fell off, need to replace this part. How do I remove the old one from the frame? There’s no screws and I can’t see an obvious lever point.
    #484310
    matrixresonator
    Looking at the diagram (see attachment) looks like the outer (0232) clips off, then 0237 and 0239 are screwed together. There are some of the newer Bosch doors where this outer twists off, so have a look before forcing anything.
    #484311
    Dcll
    Tried everything I can to twist it, but doesn’t seem to go. And not really any solid holding points
    #484312
    if you look at the enlarged pic on the bosch site you will seee its got clips on the inside
    https://www.bosch-home.co.uk/store/0…lebox=manuals/
    matrixresonator
    Manufactorers seem obsessed with making things hard to get into.
    #484314
    tubafan
    I’d use a spudger to go around it and release each clip in turn. Doesn’t look like it should be too difficult.
