wanted… Pcb aeg f35080vi
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts wanted… Pcb aeg f35080vi
  • #85783
    Aeg f35080vi Pnc 91123536800
    anyone got kicking around in there scrap pile? I need a 2nd hand pcb for this dishwasher as long as on off switch works on the board that’s all I need off it, got a machine with this fault
    and just need the switch off the board,
    canufixit
    #429529
    Re: wanted… Pcb aeg f35080vi
    had a few with this fault but not gat any scrap boards at the mo
    had a bit of sucess by taking apart the switches and re-grooving the latch mech inside. the plastic grooves wear with switching on and off so the latch wire goes down the wrong path
    ok , thanks for that i might have a go at that then? , will up date you
    canufixit
    #429531
    well had a go at the switch but no joy, but I see what you mean
    about the switch ended up with a new pcb being fitted
    canufixit
    #429532
    was worth a try but it one of those problems
    if the customer turn it off all the time the switch goes and you have to replace the pcb
    if the customer leaves it on the pcb burns out (or goes on fire) and you still have to replace the pcb
