Can anyone help with this one – pumps away fine, no play on impellor, and pump doesn’t get warm, but if you put it on any program it just doesn’t finish properly. Instead of getting the -0- beep you get – – flashing. Had the same model with ber drum failure stripped down so have tried pressure switch, door lock, motor, door lock cable, and im baffled. Haven’t tried new pump as connect have been out of stock of the 6blade versions. Not PCB either as stripped model PCB also showing this “code”. Interesting I couldn’t get it to show no/yes at all but it’s done it once whilst i paused it trying drain after booking up all these bits but even though it was empty it still wouldn’t release door Or say yes. Have blown down pressure switch hose and it whistles freely into drum.
