Warm fridge
  • #97576
    dasling
    Hi this as probably been covered many times but any advice would be appreciated, i have a old prima lpr255 fridge freezer, compressor works comes on and off, freezer very cold but fridge to warm, i realise the original thermostat is no longer available but not even sure if this is faulty, so scratching my head what the problem could be, thanks
    #468449
    since the compressor is going on and off and the stat is in the fridge it seems likley it may be faulty. I assume you have turned it up to the highest setting
    have you measured the freezer temp to make sure its within spec
    and are you sure compressor is going on and off ?
    stat looks like it may be available. from the research i did it looks like there may be 4 stats in the site shop that may fit but would need the 12nc number to confirm as there are 6 units with the same model. number look like 8539 759 15000
    dasling
    Firstly thank you for your reply, temp in freezer down to around – 20 overnight, yes turned up to 7 on dial and model number 8539 759 15002 and compressor definitely going on and off, thanks
    #468451
    thermostat gen part no 4819 271 29054
    https://shop.ukwhitegoods.co.uk/a13-0447-fridge-freezer-thermostat
    at that price its worth a try as it does sound like the stat is turning things off too early from what you stated
    dasling
    Thanks for that i realise i will need to adapt the original wiring so this item would fit is that a difficult job im fairly useful at DIY I’m joiner by trade,thanks there is also a local electronics company who say would look at the original part but they will probably charge around £50 so if its easy to adapt new thermostat could be a better bet
    #468453
    why do you need to adapt wiring ?
    have not seen old one so wont know any differences
    dasling
    Sorry tried to upload image but unable to if you have a email i could show you, the earth pole is different only one on one side in the middle
    #468455
    have pm,ed you an email address i can access to look
