Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Warm spot on side of Liebherr fridge
- This topic has 7 replies, 3 voices, and was last updated 7 years, 3 months ago by
Marcus_2018.
December 22, 2018 at 1:23 pm #95188
Marcus_2018
ParticipantHi Our fridge just developed a warm spot in the middle of the right hand wall in the refrigerator compartment (which is above the freezer compartment). The warm spot is directly below the light / temp control box. Overall the fridge is still cool, and freezer seems fine.
The fridge is a Liebherr CUP sl 3021
I did a search and looked at the sticky, but couldn’t find anything to address thisThanks for any help!
December 22, 2018 at 5:52 pm #459647kwatt
KeymasterI’d need the service number to check but it sounds like the anti-condensate line and if so it’s normal and of no concern.
December 22, 2018 at 10:11 pm #459648Marcus_2018
ParticipantThanks Kwatt It is 9989930-01
December 23, 2018 at 12:59 am #459649kwatt
KeymasterAll I can think on is the light not switching off, a possibility or the aforementioned anti-condensate line.
Prove the light by pressing the switch and see if it goes off, it if doesn’t, there’s your problem.
If it does I wouldn’t be too concerned as all that’s there are the light and a thermostat and aside from stripping that all out to look you can’t go any further but it sounds like a non-problem on the pace of it.
December 23, 2018 at 9:00 pm #459650Tony R
ParticipantIt will be the winter mode heater, it is activated by the cool plus switch, it is designed to warm the area just below the thermostat housing to ensure the thermostat brings the compressor back on in low ambient temperatures, it is only used if the room temperature is too cold, if its not just flick the cool plus switch to 0.
December 30, 2018 at 9:36 pm #459651Marcus_2018
ParticipantThanks for the responses. I have been away, so only just checked the light. It does switch off. Have tried flicking the Cool Plus switch to 0, and will see what happens.
December 31, 2018 at 10:36 am #459652Marcus_2018
ParticipantFlicking the CoolPlus switch seems to have worked – thanks! Can’t remember if I ever changed it in the first place… Again thanks for the help
December 31, 2018 at 6:41 pm #459653Tony R
ParticipantYou are welcome, on some versions with a winter heater it comes on automatically, controlled by an ambient sensor, Ken was also correct as some versions use the light as the heater by staying on at half power when the cool plus is turned on, bright when door open, dim when door closed.
Tony. -
