Warning qualtex car99 do not fit
Home Forums General Trade Forum Warning qualtex car99 do not fit
  • #100031
    Simon46
    Having fitted 7 of these and 6 have resulted in no spin. blown armatures and module and burning smells on wash.
    Carbon holders plastic is not heat resistant and melts around brush jamming carbon In after 2 washes.
    Similar to some white hotpoint carbon brushes of old.
    If needs be I recommend fitting customers old plastic casing around new insert.
    Hope it saves you guys a lot of bother!
    Regards
    Simon
    #478971
    I have got more and more disillusioned with non gen parts. where possible i will use the gen parts
    In the case of Car99 i use C00311010
    its cheaper in the long run as i dont get call backs
    I dont know if its Qualtex trying to make more profit, Bad chinese parts or Qualtex lowering quality because some engineers are greedy and want the cheapest parts possible so qualtex is just providing a service
    What I would like to see is a range of premium alternative parts so we could trust the quality
    kaibart
    I agree dave I only use genuine Brushes
    #478973
    DavidQ
    Simon46 wrote:Having fitted 7 of these and 6 have resulted in no spin. blown armatures and module and burning smells on wash.
    Regards
    Simon
    Hi Simon, My name is David and I work for Qualtex, upon reading your post I have passed the information on to our purchasing team and they would like to do a full investigation. I have sent you a private message with more details.
    #478974
    Hi David glad you picked this up
    to add to it
    car 93 the angle on the end of the brush is slightly out and they spark badly unless you take emery paper to the heel of the brush. if you dont do it the heel of the brush contact the armature leaving a gap under the brush. if you emery the brush the middle of the face contacts the armature
    car79 the case melts and jams them. the plastic used is not able to withstand as much heat as the gen pair
    car121OQ the brush fits fine but the metal top wont lock in the top of the holder
    There will be others, this is all i can think of quickly but is does seem some of the quality has gone out of pattern parts. The problem for you is you dont hear about some of the problem as i have no-one i can tell anymore. plus if the spare is cheap i just bin it and never buy again
    kladave
    Regards
    Simon
    Funny enough (well I certainly hope not!!) I had issues last week with CAR99,the amp connector appeared to be a tad wider resulting in it being bent as I fitted the lead.
    I did make a mental note not to buy those again.
    #478976
    mike1
    connect non gen brushes cbn9041 appear to be gen ones
