Washer Dryer
Home Forums Public Support Forums Buying Advice Washer Dryer
  • #62576
    deegee
    I know I should really buy separates, but we’ve only got limited space. The dryer isn’t an important part of the package, but would be useful to have.
    We have a Candy at the moment, but it’s now fubar, so I need to replace. This deal at Comet has caught my eye:
    http://www.comet.co.uk/p/Washer-Dryers/ … ulldetails
    There’s got to be a reason that it’s so cheap, though – right?
    Any other suggestions as to what I might like to get. My budget is pretty restricted. There’s two of us and a toddler, so the washer is getting some heavy use, and we don’t really use the dryer that much…
    #350533
    don
    Re: Washer Dryer
    Hi deegee
    If you can do without the dryer then don’t go for a washer dryer as they don’t do what they say. The only one that does the job is the Miele at over a thousand.
    Washer dryer buying guide is a good read to see where we are coming from.
    Needless to say the Indesit is not a good bet 😉
    I would recommend the Bosch WAE24060 for the same amount of money as the Indesit. It will outlast the Indesit by a long distance and have a two year warranty.
    If later on you find you are not coping without a dryer I would probably get one of the White Knight 3 kg compact dryers which you should be able to pick up for around the £110 mark.
    HTH 🙂
    Don
