washer dryer APM8703 not drying
Home Forums Public Support Forums Help And Support Washing Machine Help Forum washer dryer APM8703 not drying
  • #35250
    boselecta
    hi i have a MFI APM 8703 washer dryer, (servis) when i select the drying option it spins and then the dial rotates to the stop position and the dry cycle ends. i get 0V to the dry motor or dry element. Does anyone thik it could be the module or the dry timer?
    #245703
    Is the half load option selected? If memory serves if it isn’t it won’t go onto the drying cycle.
    Saying that, again from memory, the dryer stats have a nasty habit of tripping out.
    HTH
    boselecta
    Re: washer dryer APM8703 not drying
    thanks kwatt no none of the extra buttons are selected. The one shot TOC (button reset) is not tripped and the other stat has continuty. I would have thought if the stats tripped out the dry fan would still come on but no power to element.
    #245705
    Washman
    The half load switch must be selected before the dryer will work.
    Mike
    #245706
    boselecta
    thanks washman, oops think you might be right on this one will go back and have a look, didn’t know half load HAD to be selected. My fault jumping in looking for difficult faults again!
