Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Washer-dryer BHWD 129 stops during pumping
- This topic has 4 replies, 2 voices, and was last updated 13 years, 1 month ago by
Mak2013.
February 10, 2013 at 9:03 pm #74068
Mak2013
ParticipantDear UKW,
I have a hotpoint/indesit BHWD 129 washer dryer which stops a few seconds after starting to pump out. The buttons lights flash continously (with no pattern) and program lights 1,2,3 and 4 are lit (1 being the bottom door lock, then “End”, dry and spin respectively). For the few seconds the pumping seems to work fine and it is possible to empty the machine by restarting the pump-out program a couple of times. The filter in the bottom was also cleared (the problem started after cleaning the filter in fact)
I understand the program lights indicate the error code but I can’t find an online technical manual unfortunately. I’ve found a few references in UKW to other models (the closest is probably http://www.ukwhitegoods.co.uk/help/faul … codes.html) but can’t be sure those apply here.
Your assistance in identifying the problem would be greatly appreciated
Many thanksMak
February 10, 2013 at 10:22 pm #389833madangler1
ParticipantRe: Washer-dryer BHWD 129 stops during pumping
If lights 1 to 4 are lit one being the bottom door lock light that’s F15 – a fault with the drier element, posable open or short circuit or earth leakage problem
Check the connections on the element a and test it with meter for continuity and earth leakage, if element fine posable board problems.
February 11, 2013 at 11:36 am #389834Mak2013
Many thanks madangler1, will try that.
To clarify, I had understood but wasn’t certain that the door lock button was just an indicator of error, not part of the error code (so probably should have called if light zero, not 1). If that’s the case then the error code shown by the other 3 lights would be 7 rather than 15?
Thanks again
Mak
February 11, 2013 at 8:00 pm #389835madangler1
Door lock is led 1 and classed as the first one.
February 13, 2013 at 5:08 am #389836Mak2013
thanks again. Can you give me an indicationof where to find the dryer heating element?
