Hi Dave,
Thanks for info.
I looked at the little Square reservoir thing on the condenser tube which is connected to the condenser inlet valve.
Water is trickling into it but very slowly and not quite reaching the hole half way up that leads into the condenser coolant tube.
Ie no cold water in tube to leech out hot moisture from drum.
That has to be the issue?
The only component to that point from the external water feed is the solenoid (new) and the tubing from it.
Check tubing for blockage?
Cheers bud.
