Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Washer dryer stops mid cycle
- This topic has 3 replies, 2 voices, and was last updated 6 years, 10 months ago by
pigglesworth.
May 25, 2019 at 11:31 am #95905
pigglesworth
ParticipantI’ve gone through the forum but I didn’t find anything that really matched the issue that I’m having. I’ve put this in the washer section as the cycle doesn’t get as far as the drying cycle.
I’ve got a Waltham WTLS75WAV14 washer dryer. Whenever I use it it stops mid cycle. It will fill with water, get soapy, and slosh things around. However at some point it will go from saying that there is still X minutes left to just saying that it’s finished. No error codes etc. It doesn’t get as far as spin, and I think doesn’t rinse either. If I put it directly on spin then it will spin no problem, the same for rinse, or dry. So each function works correctly, but it won’t move through the full sequence. However there is one function, “easy maintenance” (it’s written in French), that works perfectly. The machine goes through the whole cycle and washes the clothes exactly how it should.
All the guidance etc that I’ve seen gives suggestions for what to do if the problem is consistent across all cycles due to a bad sensor, switch etc, but not what to do if one works normally. Does anyone have an idea for what might be causing this? A replacement control board is pretty expensive so I don’t want to start replacing things like that unless it’s god a good chance of fixing the machine.
I can’t find the user manual online, and there doesn’t seem to be any way of contacting the manufacturer. Waltham is apparently owned by Vestel, but even they only have a postage address and no mention of Waltham on their website.
Thanks for reading, and for any advice.
May 25, 2019 at 1:39 pm #461667electrofix
Moderatorseems to be one of those obscure makes cant find anything on it.
may have just been marketed in France
If it is Vestel it should have a long number on the rating plate which should also say where it is made
one fault we do get on a lot of machines is earth faults on elements upsetting the electronics. try taking the wires off the tumble dryer elements, insulate them and see if the wash programme runs
DaveMay 25, 2019 at 3:33 pm #461668electrofix
Moderatorcant find anything but that’s not unusual for vestel
June 13, 2019 at 11:44 pm #461669pigglesworth
ParticipantI did a wash cycle with the drum empty save for 500ml of vinegar. That did the trick, the machine has been perfect ever since. It must have just been a build up of stuff blocking the water level sensor. Thanks for the help!
