I have a hotpoint ultima wt960 washer and it will not turn on.
I have checked and changed the fuses but it makes no difference, is there an in line fuse that I can check please?
It worked fine early in the day and was switched off by thye button as usual.
If it is totally dead with no lights on the display but you can get a circuit from the plug top to the mains filter then it is more than likely a main pcb failure.:(
Yes you are right , there are no lights on the display and the power on light does not light up when you press the on switch.I take it the mains filter is the cylindrical item which the main power lead goes into.
