Washing machine Bosch Maxx 5
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Washing machine Bosch Maxx 5
  • #87007
    Derek Carter
    Bosch Maxx 5 WAA 241 66GB
    I have successfully replaced the door seal, but on first empty test I still have some rubber degradation on the seal. I think the drum and outer tube may be out of kilter. Diagnosis and cure please.
    #433659
    Re: Washing machine Bosch Maxx 5
    from what you describe the inner drum is catching the door seal and i guess you have replaced it because of this problem
    this range of machine is known for this problem being the cheaper machine at the lower end of the market
    if so scrap it time for a new one. drum spider has corroded and snapped
    DixonsDan
    I’ve had this with a few Electrupart door seal on Bosch. Found it best to get genuine Bosch seal.
    #433661
    DixonsDan wrote:Found it best to get genuine Bosch seal.
    It’s a Bosch WAA Dan, I’m with Electrofix on this one, the drum shaft is a gonna no matter what door boot was fitted.
