Washing Machine – Burning Smell
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Washing Machine – Burning Smell
  • #102534
    Annaa1982
    Good Morning,
    I turned my washing machine on this morning and within minutes there was a burning smell. I turned off and unplugged it straight away.
    There was no visable smoke, odd noises etc.
    It was just at the filling with water stage.
    Any idea what it could be? – Innex XWE91483X
    Motel Details – Indesit Innex XWE91483X
    #489338
    its impossible to tell what it is from that description
    there is not much running while its filling but the drum maybe turning
    andyjawa
    Could be loads of things based on the info given: Could be the suppressor (could be though hardly that common), possible heater coming on before it had filled (not common), motor even (not common, well not like that), or pump (not common on fill), valve melting (not common that one), pcboard perhaps (not that common, they usually just go pop or do nothing). More likely to be the door lock`s connector block/wires (door lock end) burning due to crappy terminal connections – someone was being a bit optimistic there!….some Indesit models were recalled due to this so go to the indesit website or google “indesit recalls”….. common problem – just google it; had a quick look for you. Your model is not mentioned but take that with a pinch of salt………could still be that problem, had it happen to many machines that are not on the list even with completely different door locks (it is not really the door lock that is the problem but the surface area, for the given current over time, of the connector block terminals..Best have a look yourself first.
