Washing machine clothes wet after cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Washing machine clothes wet after cycle
  • #102934
    ralph47
    Hi got a problem with my 6 month Bosch series 4- 8kg washing machine.
    After a washing cycle (Eco 40-60 or Mixed load/1hr daily type cycle) my clothes are still very wet with water, it could be anything from light aprons or t-shirts or towels.
    Its very random though so sometimes my clothes come out dry and other times soaking wet.
    I clean the filters regularly and run a drum cleaning cycle often also and water is exiting out the drain correctly.
    It behaved well for almost 6 months with it only rarely happening but now its happening a lot more.
    Any ideas on what the issue may be? thanks
    #491127
    Is it smal loads you are doing as that sounds as if it’s a load imbalance issue?
    you cant balance the load as such. the minute the machine tumbles anything you do has gone. the main thing is you put enough in for the machine to be able to balance it
    ralph47
    electrofix wrote: you cant balance the load as such. the minute the machine tumbles anything you do has gone. the main thing is you put enough in for the machine to be able to balance it
    ahh ok I did think so, we have also been trying to add more into the machine so that makes sense why its coming out dry now. Will keep this in mind for future washes thanks.
