I have a issue with the washing machine door. The model is a Siemens WM12Q362GB/09, on the inside trim that surrounds the glass this is coming away from the hinge side. I thought the trim would be held by screws but not seems to be some white rivet style fixings that cannot be removed and these seem to be missing that side. Is this a case of replacing the whole door ?
yes its a complete door
but if its only the head of the rivet that off the stud has a hole in the middle. find the right size self tapper and you can sometimes fix it
