Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Washing Machine Drum Movement – Is this normal?
- This topic has 5 replies, 4 voices, and was last updated 4 years, 4 months ago by
Dazie.
November 28, 2021 at 8:14 pm #100292
Dazie
ParticipantHi all,
ZANUSSI ZWF1430W
My w/c had a small leak and when I removed the top cover I found that the small top vent hose was the source. That has now been fixed by replacing the hose.
However, in the process I observed the drum and noticed it moving around a lot. The problem is that I don’t have experience of doing this on another w/c so no idea if this movement is within normal range or if it is excessive.
This link shows the w/c doing its wash cycle: https://youtu.be/uJLYt8HD-Vc
This link shows the w/c draining and ramping up for its spin cycle: https://youtu.be/l-gp–lpdXk
Does anyone have a comparison to know whether this is normal or not. If not normal then I presume I am looking at replacing the two shock absorbers at the bottom?
November 28, 2021 at 9:31 pm #480021electrofix
Moderatorlooks normal to me
November 29, 2021 at 8:31 am #480022tubafan
ParticipantI’d say it’s ok too. When the dampers on my Gorenje machine were shot the drum was sometimes hitting the side of the machine and it was also trying to walk its way out from under the worktop!
November 29, 2021 at 6:25 pm #480023Dazie
ParticipantThanks for your input [USER=”18369″]tubafan[/USER] and [USER=”4209″]electrofix[/USER]. No noises or movement with the lid on, but I just thought it was quite a lot of stress being added to that top vent (which may have made it fail) and the door seal. But if you think it is normal I will leave alone for now.
December 9, 2021 at 4:23 am #480024andyjawa
ParticipantHmm. I disagree. I personally think the bottom shocks are going, the machine is the right age for this to happen too and it should not be moving as much. The tank breather pipe is being pulled which is not good either as the plastic tank has or will wear the rubber away where the hose fits into the tank = hence leak. I think you would need 2 shocks and a new breather pipe. Shocks are sold a singles part number 3794303010 at 24 quid each ( so you`ll need 2, they are both the same ) and the steam vent hose ( that I call the breather pipe ) is part 1322899004 @ 10 quid all parts quoted off Zanussi spares website and based on your model number as product code 91451723100 – check your label. You might get them cheaper elsewhere, maybe check the prices on uk whitegoods spare site, frankly at 4.20 am I haven`t. What I can tell you is that the shocks are 22 quid plus vat each off the so called trade site called Qualtex and so are more expensive than buying from Zanussi direct! Who says that this trade does not make sense?
December 13, 2021 at 6:35 am #480025andyjawa
Participant3794303010 £9.95 on ebay for 1. A better price b
