Re: Washing machine drum wobble
From what you describe it sounds pretty normal you should see that with any sort of load, on spin especially at low speeds. Once it accelerates that wobble with disappear totally.
Incidentally, if your machine is free standing it is important the adjustable feet are adjusted correctly and locked into position. There should also be a free gap all around the machine of at least 1cm to allow the cabinet a little vibration (wiggle) room. When you say “wedged in” it should not be literally so as that could compromised the machines stability tolerance.
