Washing machine flooding
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Washing machine flooding
  • #6218
    I have a 16yr old zanussi washing machine which has given good service. I have now started having water coming out of the soap drawer. I have removed the drawer and cleaned all the Gunk out but still have water flowing out. It appears that the water level in the Drum is correct,,,, but if I pull out the draw I can see that water wells up from the drum. Please could you advise on possible cause. 🙁
    #116374
    Most likely a faulty pressure switch, blocked pressure switch hose or the filter chamber blocked.
    Should be easily enough repaired and not too expensive either.
