Washing machine grinding sound before drum spins- is it definitely the bearings??
Home Forums Public Support Forums General Enquiries And Questions Washing machine grinding sound before drum spins- is it definitely the bearings??
  • #103653
    kaidaw
    I’ve got a Beko washer dryer and it makes a grinding sound when I switch it on.
    Thing is, it seems to happen before the drum spins, and it doesn’t seem to happen on every setting I use.
    I’ve had a chat with a couple of washing machine service people and both have said that if it’s the bearings it’s better to just get a new machine.
    Does this sound like it’s worth getting looked at at least?
    Thanks for any help!
    #494102
    If you turn the drum by hand is it noisy or feel rough?
    kaibart
    Check to see that you haven’t got a coun blocked in the pump impeller you can do this by removing the filter and shining a touch in where you have removed the filter make sure that the power is off before hand and you have towels to hand
