Washing machine leaking indesit W123
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Washing machine leaking indesit W123
  • #36650
    dysteve
    I have an indesit w123 washing machine, it is leaking water from the bottom while switched on and now when not in use, any ideas why?
    #251820
    philfish
    Re: Washing machine leaking indesit W123
    if it’s leaking constant when not in use check your fill hoses
    #251821
    dysteve
    I have checked all the hoses they seem to be fine and are not leaking!
    #251822
    Filter cover weeping?
    stripey
    To see if it is a filter problem remove the kick strip at the bottom may need to prise it off with a screwdriver. Pump is located at the RHS check that the seal has not perished.
    #251824
    dysteve
    Thanks will try this and get back to you
