Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › washing machine no power
- This topic has 9 replies, 4 voices, and was last updated 13 years, 5 months ago by
MRKB.
October 14, 2012 at 9:46 am #71952
MRKB
ParticipantHi, We have a hotpoint aquarius wf321, it was last used 3 days ago and worked fine, come to use it 2 days later and nothing, no power light, nothing lighting up on the dash at all, checked the wall socket and checked the plug, had the top off the machine and back panel,cannot see any loose wires and no smell of any burning, the thing is just dead, any help would be greatly appreciated.
Karl. 🙂
October 14, 2012 at 11:11 am #382875kwatt
KeymasterRe: washing machine no power
Mains cable, mains interference filter or the main power switch faulty could all cause this.
October 14, 2012 at 12:12 pm #382876Allsorts
ParticipantRe: washing machine no power
Also check to see if it has tripped the RCD in the main consumer unit.
October 14, 2012 at 1:29 pm #382877MRKB
kwatt wrote:Mains cable, mains interference filter or the main power switch faulty could all cause this.
the mains cable and switch are fine.
October 14, 2012 at 1:34 pm #382878MRKB
Allsorts wrote:Also check to see if it has tripped the RCD in the main consumer unit.
RCD is ok
October 20, 2012 at 3:43 pm #382879MRKB
Am back again, Had another go at the washing machine today, double checked the things I already looked plus checked the power cable filter and thats ok, replaced the door switch thats ok, replaced the front panel pcb, checked the motor brushes ok, I think the only thing left to replace is the main control panel. any other things I should check before I get another control panel. :hmm:
October 21, 2012 at 8:14 am #382880bryan-206
Do you have power going into the machine?
October 21, 2012 at 8:15 am #382881bryan-206
Unplug the wiring block from the mains filter. Common for these to burn out.
October 21, 2012 at 9:35 am #382882MRKB
Hi, yes I unpluged the wiring block on the filter, this is where I checked for the power coming into the machine.
October 22, 2012 at 9:25 am #382883bryan-206
Then assuming you have changed the fascia board and you have power going to the main board. I’d say the main board is faulty.
