Washing machine, Not letting conditioner drain….
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Washing machine, Not letting conditioner drain….
  • #9514
    Weirdjam
    I have a friend that has a washing machine that when you put fabric conditioner in the tray it stays there through the programme. I dont fix washing machines so have no idea. I presuming it could be timer related or even something simple like blocked pipe?
    Any advice. I’m going over later to destroy it 😈 I dont even know what make it is!
    Ta for any help
    Jamie
    #134426
    Re: Washing machine, Not letting conditioner drain….
    An unusual Trade question?
    However, a good clean out inside the dispenser cavity including all the holes cleared of limescale and bateria build-up will suffice to cure 😉
    Weirdjam
    well i’m in the trade…….
    its a technical thing………..
    and its an enquiry…………….
    Thanks for the help! 😀
    I could have put it in the general washing machine bit i suppose. 😳
    #134428
    andy2
    What make of machine is it?
    Why?
    Because some machines rather than use another valve for the fab con have a device fitted to the top of the soap dispenser to divert rinse water into the fab con dispenser. This is operated mechanically by means of a lever attached to a cam follower / cam on the timer shaft.
    Sometimes these can become stiff due to a build up of powder / cr@p on the top of the dispenser. Also the return spring may be unattached or broken.
    Andy
