washing machine not spinning
Home Forums Public Support Forums Help And Support Washing Machine Help Forum washing machine not spinning
  • #30025
    stretch79
    hi all i have a bosch wft2800.
    now i put a rather large load in and now it has stopped working, it doesnt spin anymore and when i put load in it spun really slow but i didnt realse so im presuming i burnt out a motor or something, it puts water in fine etc just doesnt spin
    so any ideas or help on what i can do would be great
    many thanks
    rob
    #225561
    gegsy
    Re: washing machine not spinning
    With unit un-plugged, I would be checking those carbon brushes 😉
    This is easier said than done on this motor though 😕 The motor will have to be taken apart 😯 to gain access to the brush assembly.
    Original brushes module is 496876 but depending how nifty you are with a soldering iron you could use BS12102 which is the cheaper but more trickier solution. Both are available from spares@ukwhitegoods.co.uk
    If you feel this is more of a task than you need then feel free to find a qualified engineer in your area from the link below 🙂
    stretch79
    hi greg well pulling apart isnt a prob its the putting together really haha, out of 5 for most difficulty how hard you reckon it is to do the above im feeling adventurous as not sure if an engineer will be to costly?
    thanx greg
    #225563
    gegsy
    Mmm I don’t know your ability but I would give it a 3 😀
    stretch79
    hi again all sorted many thanx, now not sure if its related but now the work has been done the machine doesnt seem to dry the clothes as much as it used to?? is this problem related or something different??
    cheers all
    #225565
    stretch79
    anyone??
    #225566
    gegsy
    Hard to say. Module may have been damaged with original fault, or motor damaged by original fault. 😕
    stretch79
    the module? any light on that please gegsy thanx for the help
    #225568
    gegsy
    Module=PCB the circuit board
    #225569
    stretch79
    and thats where abouts in the machine so i an replace it if nessecary, cheers
    #225570
    gegsy
    Its in the base near motor but at approx £175 + and the motor approx £158 + the usual you better be sure which are at fault 😯
    stretch79
    ok cheers gegsy may just get a new machine if its easier thanx again fella
