Washing machine skips hot wash: EWD12141
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Washing machine skips hot wash: EWD12141
  • #82349
    neilsukwg
    Product number : 914674107
    Complaint is that the programme switch skips through B (90) and C 60 degree wash straight into D the 40 degree wash.
    Machine works normally apart from this.
    N.
    #419587
    Re: Washing machine skips hot wash: EWD12141
    2 possibles : the indicator dial broken or the holding solenoid in the timer is stuffed?
    #419588
    jag-12
    Have you checked to see what it actually heats to when set to B and C as have an idea that this is actually the way the timer functions on these machines.
    Program starts by pumping out then advances to fill then onto heat
    #419589
    timdowning
    I agree with jag-12. Get them to do the B wash and periodically check the glass.
    #419590
    …….but it won’t stop on B
    #419591
    neilsukwg
    Yes that s the problem…
    if you choose B it does the test pump and then the programmer switch steps forward until it stops at D
    It the works normally after that completing D
    #419592
    You might find this of interest……
    #419593
    neilsukwg
    Excellent thanks Martin
    Just saved me a whole lot of unnecessary work
    Just got to convince customer its working normally now!
    #419594
    timdowning
    That’s what jag-12 and I were saying. The temperature of the glass is the proof and the manual. Also, no martin it won’t stay on B it never did.
    #419595
    neilsukwg
    These machines are double glazed so the only way is to measure temp of waste water or maybe an infra red thermometer might give a reading
    #419596
    That’ll work either way.
