Washing machine too wide
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Washing machine too wide
  • #10941
    kernelmart
    Just bought a new washing machine (the old one packed up). The new one doesn’t fit in the gap the old one came out of.
    Does anyone know of a current washing machine that is about 58cm wide? All seem to be 60cm now.
    Thank you,
    Dave_Conway
    Re: Washing machine too wide
    I don’t think there are many to be honest, if any at all these days.
    A check of the manufacturers sites will give the info for you 😀
    #143294
    kernelmart wrote:The new one doesn’t fit in the gap the old one came out of.
    If your machine is intended to fit in between todays modern (MDF constructed) type kitchen furniture, then it is a simple exercise to adjust the cupboard units to make it fit nicely 😀
    Most cupboard side panels can easily be removed, shelving shortened slightly and the side panel replaced to give you that extra centimetre or more you require to slide it in. 😉
    Contact your local friendly chippy (carpenter/joiner) if the DIY challenge appears too daunting ❗
