Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › washing machine unable to do a 60 degree wash ?
- This topic has 4 replies, 4 voices, and was last updated 18 years, 5 months ago by
fendertele.
October 21, 2007 at 6:23 am #31546
fendertele
ParticipantHey was wondering if some one might be able to help.
We got a hotpoint washing machine fitted yesterday, and it can do anything up 50 degree washes fine but as soon as we select anything higher it doesn’t do anything.
when it was fitted he only installed the cold water hose onto the back and not the hot water one saying that the machine will heat the water and so the hot one isn’t needed ?
is it possible that without the hot water hose the washing machine is struggling on a 60 to heat the water or is it something else that may be causing it ?.
thanks for any help. Kevin
October 21, 2007 at 8:34 am #231616Washman
ParticipantRe: washing machine unable to do a 60 degree wash ?
Hot water hose needs to be connected , when on 60 deg wash or higher is selected it starts to fill with cold then changes over to hot water fill .If hot not connected machine will not advance as it is waiting for more water to be added. So connect hot water hose.
Mike
October 21, 2007 at 8:35 am #231617Dales-Electronic
ModeratorRe: washing machine unable to do a 60 degree wash ?
Two points – does the washing machine have hot and cold connections on its rear? If so you will need a hot and cold water feed to make it work above 60C (washing machines generally with two inlets hoses fill through both hot and cold on a 60C wash and through the hot supply above this temp on the wash program) If it only has one connection at the back you have a fault with the washer.
October 21, 2007 at 9:36 am #231618Washman
:waving: :waving:Mike
October 22, 2007 at 10:18 am #231619Allsorts
Is this a new machine ❓
➡ If the machine has both pipes fitted check that the Hot is actually turned on… Another thing is… If it is turned on, make sure that the pipe connection is actually creating a flow, sometimes the knob will turn but the center of the connection will not actuate so you will get no water.
➡ If the machine is not new… Check that the hot water inlet is working
➡ Should the other two resloves not be the answer.. I would suggest the heater
