Washing Machine widths
Home Forums Public Support Forums Buying Advice Washing Machine widths
  • #103457
    KevB
    My elderly parents live in rented accommodation where the space in the kitchen for the washing machine is 59.5cm. The have a Bloomberg device squeezed in there at present but this has stopped working and I am trying to source a new one on a tight budget. For various reasons they need a machine that can do an 8kg load every 2nd day, with a high spin speed to quicken drying times.
    I am having difficulty finding any “true size” info on generic searches as everything defaults to “standard 60cm” sizing when I know this is slightly different from one manufacturer to the next.
    So, can anyone help with a brand/model that is perhaps 58.5 – 59.4cm in width?
    #hopeful
    #493229
    your going to struggle
    manufacturers design for a 600mm gap that means the machine are slightly narrower to allow the unit to slide in. how much narrower no there’s a question
    sizes vary between manufacturer and even slightly between 2 identical machines and your right they dont publish actual sizes because they can vary
    will tag don in our retail guru to see if he has any ideas
    [USER=”125″]don[/USER] any ideas
    #493230
    don
    The only ones I know of are Hisense, Hotpoint and Indesit which are 59.5cm wide. They all produce an 8kg 1400 spin at under £300.00.
    Don
