washing machine will start after a battering
Home Forums Public Support Forums Help And Support Washing Machine Help Forum washing machine will start after a battering
  • #9149
    i have a : hotpoint wm63 and no serial number i can find which is strange?.
    my issue is the the door needs to be shut some times once sometimes 20 times to get the red light to come on, i always leave it 2 mins between each shutting of the door. i have cone to the conclusion that this is a issue with the metaflex tip zv-445 as when the light comes on the machine is ok and i have taken the lid off and this part nees a few gentle taps when in the curcuit breaker/door closed position and then works fine. do you agree with this if so where can i get a new metaflex tip zv-445 part and the front plate that it conects to so the door lock can work
    thanks
    #132663
    Dave_Conway
    Re: washing machine will start after a battering
    It will be the door lock, just replace it they are reasonable enough and a very common part 😉
    In the shop here
    http://www.ukwhitegoods.co.uk/modules.p … ucts_id=86
    Excuse the rather “squashed” image 😀
    Pull the plug before fitting please :zap:
