I have a indesit iwde 12 washing machine and every time i try to run a cycle it stops after about 5 mins half full with water and the following lights flashing, the lock button, 1200/600, the basin with water droplets and the clock. I have already tried removing the filter at the bottom and clearing out any objects objects but this didnt help.
so after looking into the errors further i have found that the error is most likely due to too much foam in the washing machine. However this doesn’t explain it not draining? Also i have run the machine a couple of times and pour some hot water through the powder dispenser to clean it but this hasn’t helped solve the problem.
