Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › washing up liquid in GDA dishwasher
- This topic has 13 replies, 7 voices, and was last updated 15 years, 5 months ago by
fasetester.
October 21, 2010 at 2:39 pm #58191
fasetester
Participanthow do you get a dishwasher sorted that washing up liquid is used in when run out of dishwasher detrgent . it is now stopped and wont go.
it is a GDA intergrated type 3.m1 what is the best way to get it up and running is their any thing you can add to it to break down the foam i have to check it today. thanks fasetester
October 21, 2010 at 5:12 pm #333670fasetester
ParticipantRe: washing up liquid in GDA dishwasher
well guys and ladies no one have to sort this out before little help would be greatfully accepted thanks fasetester
October 21, 2010 at 5:57 pm #333671eastlmark
ModeratorRe: washing up liquid in GDA dishwasher
think you will find most folks are out working between 2 and 5.
scoop out the foam, clear the undertay, and give it a few rinses, scoo[ping out every now and then.October 22, 2010 at 11:05 am #333672jag-12
I find if you put milk in the machine it kills the foam. No idea why but it works.
Alternatively if it is detergent the add a couple of scrapes from a bar of soap. Test by running a bar of soap over the foam and it should collapse.
If they used soap the add a couple of drops of detergent.October 22, 2010 at 12:49 pm #333673realengineer
there we go
i ALWAYS use olive oil half a glas
put the machine on after adding olive oil
wait 20 seconds and see all foam gonethank me grand ma 😆
October 22, 2010 at 2:50 pm #333674fasetester
thanks guys for your reply went to look at dishwasher the woman said it is not heating and keep running. wont stop their still seems to be some foam in it cant get it on rince program. for it to pump out .
checked heater and 3 stats in the door the are all open and closes when heated the heater is ok. it just keep washing no heat and wont move in cycle their is a timer in the bottom at the front.do you have to move the timer by hand to get it to heat and rince. and when you hang the wooden door and get the screws in at the top it comes out the bracket
retainer at the bottom the inner panal seem ok all screws in place fasetester
October 22, 2010 at 3:17 pm #333675timdowning
You can turn the timer using a torx screwdriver. You must make sure the timer is at the 12 oclock position when you have finished your checks.
The overfoaming has more than likely caused the overheat stat at the back of the machine to trip.
MAKE SURE THE MACHINE IS UNPLUGGED and reach through above the heater box towards the back and just slightly to the left, thats it nearly there. You can then reset the stat by pushing down on it.
Keep your phone in your other hand to call the fire brigade in case your arm gets stuck. 🙂
October 22, 2010 at 4:06 pm #333676fasetester
thanks tim should i have to turn the timer to get it to move say heat and empy out you take a flap off under the door and the heater is on the left. you say their should be a over heat stat.
towards the back should i turn the timer to a rince and pump out and make sure all the foam is washed out before resetting stat. and why will the kitchen door not go on it should slot in to the opening at top and bottom. then the woman is saying can i help i am afraid of her getting sliced on raw edge.
the stand over you and watch every move i just seen watch dog that boy is some cowboy he does not even take the machine out to check it out.
then takes the money for a new machine does not deliver machine keeps the money then removes interlock i saw he was in a laundry what did he do their.missed that bit.
October 22, 2010 at 4:17 pm #333677timdowning
Other than coming to do it for you I don’t know what more I can do or say.
You’ll be fine. Talk the talk. And the customer won’t breathe SO hard down your neck.
Tim.
October 22, 2010 at 6:52 pm #333678DDDave
jag-12 wrote:I find if you put milk in the machine it kills the foam. No idea why but it works.
.Milk has a high fat content. Washing up liquid disolves fat / grease and is used up doing so.
October 22, 2010 at 10:20 pm #333679realengineer
like i said
OLIVE OILGRAND MA LAWAYS RIGHT
October 22, 2010 at 10:22 pm #333680realengineer
HALLO
JUST TRY IT
THEN SAY BELGIUM GUY RIGHT AFTER ALL
dont forget
reset tocyo yo just do it
October 26, 2010 at 5:04 pm #333681fasetester
thanks guys for all your help tim it was some job getting my hand in over the heater box lol fasetester 🙂
October 27, 2010 at 7:20 am #333682Gazman1000
It raises the surface tension of the water solution, any fatty liquid would have the same effect. Soap lowers the surface tension, hence the bubbles.
Dishwasher powder does not change the surface tension of the solution, in fact it is a non detergent cleaner.Science lesson over, back to work chaps 😉
