I went to a couple of Hoovers this afternoon, a washer dryer AND a washer, both needing their door seal changing (one ripped, the other one had come off because the laundry got caught in it and damaged it). Strange to have this combination of appliances I thought, and when I got there, they also had a tumble dryer. Anyway it turns out they used to have a Haier Laundry Centre, which is a machine with a washer at the bottom and a tumble dryer at the top, see this link:
https://www.haier.com.au/laundry/washing-machines/12kg-plus-9kg-600-series-laundry-centre-heat-pump-dryer-hlc1290ctb1-62379.html
This is an Australian site, you can’t get them here, however I have seen this:
https://www.johnlewis.com/lg-wt1210bbtn1-washtower-washer-dryer-12kg-10kg-load-1400rpm-spin-black/p112485759
This sends shivers down my spine!!
Back to the customer, they ended up with the two Hoover machines, because the Laundry Centre broke down and nobody could fix it (surprise, surprise) and Haier/Hoover replaced it with what would be the closest equivalent.
