Water building up at bottom of fridge Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Water building up at bottom of fridge This topic has 2 replies, 2 voices, and was last updated 16 years, 11 months ago by borderfox100. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts May 1, 2009 at 4:31 pm #45387 borderfox100Participant Zanussi Fridge/Freezer Model:Z 56/3 SI Product No. 925 881 658 Serial: 13000088 Have noticed over the past few weeks that water is beginning to build up at the base of the fridge. ie. a small pool of water gathers at the bottom. I thought it had to do with maybe a blockage of that hole at the back of the fridge but I checked it and it seemded to be ok. What would cause this to happen?? May 2, 2009 at 12:33 pm #285521 spimpsParticipant Re: Water building up at bottom of fridge Blockage is likely furthern down in the pipe. You need something likean electrical cable tie that is flexible,poke it down the to clear any debris. Don’t use anthing sharp like wire or you mat puncture the tubing, May 2, 2009 at 12:45 pm #285522 borderfox100Participant Re: Water building up at bottom of fridge @spimps: Thanks, will give that a try. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
