We bought one of these amervican f/f’s from a trader on ebay. There’s no accompanying paperwork or manuals. I’ve downloaded installation guide and instruction manual from whirlpool website.
I’ve installed it but the water dispenser doesn’t work.
Is there somethin I have to do to activate it? If not is there a common fault or problem?
there is generally a connection behind front plinth to connect the door to the water check if water is reaching here also when you press the lever for water can you here the water solenoid buzz?
