one of two things . Is it clean water or dirty water?. If its clean there’s a fair chance the electric valve that allows water into the machine is letting water into the machine when it should be closed and needs to be replaced. If its dirty water its down to your plumbing the grey waste hose must go upwards from the drain spigot under the sink so drain water cant run from the sink into the machine
