Re: Water flow on Hotpoint
I have deleted your other post on this topic, it makes sense to keep it to one thread or you may end up getting conflicting or duplicate replies. 😉
The condensor valve is energised continually on this model and should only trickle the water in.
It could be the valve is faulty, or it is not draining correctly.
Have you tried the machine with only the condensor valve connected to eliminate the possibility of the other valves being energised in error ?
Might be worth removing the eco ball, just in case it is sticking in the sump hose.
