Water in base
  • #57785
    kladave
    I have had a couple of these with water in the base of the machine,but customers have not said about leak,called out for other faults.
    Now iv’e looked over the machines and can’t find anywhere it’s likley to be coming from,any suggestions please??
    aqualectric
    Re: Water in base
    Hi, Dave!
    Remember us talking about the soap hose contacting the tub rim on the ISE variant and how to remedy it? The Amica is probably doing the same.
    Go on the ISE forum and read the “AW23 soap hose” thread; it may help.
    Cheers,
    Steve.
    #332299
    Steven
    Re: Water in base
    You will find that the customer has just checked the filter before you arrived to make sure nothing in it.
    Steven
    #332300
    kladave
    Re: Water in base
    aqualectric wrote:Hi, Dave!
    Cheers,
    Steve.
    Hi steve
    yep can recall our chat but what i can’t understand is that water had collected on the angle of the pump filter,to me that suggests a dispenser drawer issue.
    Steven
    Re: Water in base
    Pump on the right? how can water from dispenser on the angle of pump?
    I had a split in the small grey drain off hose from filter recently?
    I have been checking the later Amica on delivery now and on all the ones I have seen the dispenser hose issue seems to have been resolved, the distance is much greater from the tub 😉
    The only way to see if it is a dispenser problem is the base is covered in black rubber bits.
    It is difficut to see the hole as it is right on the shoulder, so you have to remove it to find it.
    #332302
    Steven
    Re: Water in base
    Found the rason for the leak on the right hand side 😆
    PRESSURE CHAMBER PIPE, chaffing against the end of cable channeling. 😉
    Needs additional sleeving or a smooth enclosed chanel conduit to come further down the side panel to prevent this.
    HTH
    Steven
