Water in inner bowl of F&P Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Water in inner bowl of F&P This topic has 2 replies, 3 voices, and was last updated 18 years, 1 month ago by geofft. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts March 7, 2008 at 10:01 am #35114 geofftParticipant Doing the cleaning on our older model F&P GW501. Discoverd the inner bowl has water in it – obviously seeped in, but how can one drain the water out March 7, 2008 at 10:35 am #245196 Penguin45Participant Re: Water in inner bowl of F&P Pick a programme and use the advance button to skip through to spin should do the trick. Penguin45. March 9, 2008 at 5:57 am #245197 kiwireefermanParticipant Re: Water in inner bowl of F&P Inner bowl is supposed to contain water. There is a hollow ring in the top of the bowl and another in the bottom. The saline solution is a balance weight. Remove this solution and machine will not be able to maintain spin balance. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
