water level switch
  • #75537
    Devlin Maguire
    W/Pool
    Model hdw1011 wg
    12nc 8570 084 15101
    is there a one way valve in the tube up to he pressure switch as I cannot blow down it, I would imagine this would hold the switch on telling the machine there is water in the drum, this makes sense as it will not come off a drain cycle,
    Devlin
    #395220
    Hollytree_Technical
    Re: water level switch
    More likely to be gunged up with soap and grot etc.
    I have never yet come across a machine with a one way valve on the pipe – it wouldn’t work if it did have one anyway as the trapped air that is used to push the pressure switch has to get out again somehow to reset it.
    Jem
    #395221
    Devlin Maguire
    Thats what I thought but I can suck air up ??
    D
    #395222
    Hollytree_Technical
    I would still be looking at the pressure chamber as it may be a bit of plastic or a coin or some other foreign object acting as a flap valve.
    Jem
    #395223
    Devlin Maguire
    Sorted soap solids in a chamber at the back
    Dev
