Re: Water not getting to upper spray arm in Tecnik TKD795/3
The heater manifold has a diverter valve driven by a small motor and gearbox. This alternates supply to the rotors to use less water and cut heating costs. If the diverter valve sticks or its motor fails, then the top or bottom rotor may be affected. Or it could be a water metering issue – caused by blockages in the fill system on the left side of the machine.
The diverter valve is not available separately and forms an integral part of the heater unit. Heater unit priced around £97.
Power off before investigating. :plug:
A.
