Our dishwasher appears to have a problem filling. The drain at the start of each cycle works OK but, when it comes to the fill, water runs from underside of the unit. The unit’s been performing fine and hasn’t been moved for nearly a year now…
Is there anything basic I can check before calling out a pro? I’m reasonably handy with a screwdriver. 🙂
Cheers,
I got inside the unit and it appears that a feed hose had worked loose. Took it off and reseated it and all OK now. Oh the joys of a successful repair! 😀
