wd002 (cuisina?)
  • #55793
    5rgj
    I realize that wd002 is probably not the model number but I’m renting the appartment so I am reluctant to start removing facias to find the rating plate.
    My research so far suggests it’s a cuisina and it has wd002 printed on the front.
    I’d be grateful if someone could help me use this machine. A manual would be great or just some clues as at the moment I’m resorting to random combination of 4 buttons and 3 dials to get it to work.
    Many thanks
    #325144
    don
    Re: wd002 (cuisina?)
    WD002 probably is the model number and from your descripton of the controls the WD part probably means it`s a washer dryer.
    I can`t find an online manual for it so if you are able to post up a picture of the fascia we should be able to help you.
    Don
    #325145
    greaseater
    Hi there,
    The company who sourced this was PABL who have now closed down.
    WD001 was manufactured by Siltal and the WD002 is either Siltal again or Fagor (If it has an LED display it is Fagor).
    WD does indeed mean it is a washer dryer.
    Greaseater.
    #325146
    5rgj
    Thanks for the replies I will indeed post pictures of the controls asap as any guidence on how to operate the machine would be brilliant. I don’t need anything fancy just a couple of simple wash programs.
    If it does turn out to be a dryer as well that would be a bonus, the agent didn’t know so I assumed it wasn’t 🙂
    #325147
    5rgj
    photos of the controls as requested:
    http://www.flickr.com/photos/52029451@N05/
    As I said any clues as to how to operate this machine would be very helpfull. Just a couple of standard wash cycles would be great.
    #325148
    don
    Select fabric type to be washed from the list ie prog no.2 is for whites at 90 degrees, turn programme selector dial on far right to corresponding number. The knob third from right will allow you to reduce the wash temperature from 90 down to 30 degrees. All you need to then do is depress the on off button.
    The other rectangular buttons from the left when pushed in will
    1 Reduce the spin speed to 500.
    2 Half load wash option and tumble dryer activation.
    3 No spin option.
    The large knob second from right is the tumble dryer run time from 0 -140 minutes. For the dryer to work you need to have the half load button pressed in. You can only dry half the normal size wash load.
    HTH 🙂
    Don
    #325149
    Higher-water-level
    Looks like a Servis to me, well the knobs and options do anyway? 😕
    The text on the drawer looks very Fagor styled though. 😮
    We have a decade old Siltal and it doesn’t look anything like that. Nothing since has come close to looking like it either. Unless its older than 10 years.
    Oliver.
    Afternoon Don :waving:
    #325150
    don
    Higher-water-level wrote:Looks like a Servis to me, well the knobs and options do anyway? 😕
    Oliver.
    Afternoon Oliver :waving: You were right first time 😉
    Don
    #325151
    Higher-water-level
    Oliver.
    Don
    The rectaungular red light was the give away.
    #325152
    5rgj
    Thanks Don you’re a star 🙂 and also thanks to everyone who replied
