Wd12 serial 4051-38617/80250570130
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Wd12 serial 4051-38617/80250570130
  • #83447
    Devlin Maguire
    Weird one, selector motors round by itself till it reaches rinse and completes the function,any ideas cheers
    Devlin
    #422807
    Re: Wd12 serial 4051-38617/80250570130
    it is supposed to do that if you move the control knob in the middle of a cycle. it will rotate 360 degrees back to where it started. You have to turn the knob to one of the three black dots to reset the timer. The selector switch could be faulty if you cannot reset the cycle.
    #422808
    Devlin Maguire
    Cheers,
    Devlin
    #422809
    Devlin Maguire
    It seems to be entirely random now the door light flashes constantly without any set pattern and does nothing else any ideas I see there are quite a few with the same issue but no definative resolution
    #422810
    Might help if you tell us what you have checked or tested?
