Where do I start. Tennanted property in an unlighted tiny kitchen and one of these piles of doo doo. Decided to loan a machine to them and get it in the workshop to try and avoid the recalls on it.
Back at workshop 13 flashes, dryer motor jammed. Freed it (spacer washer snapped internally) still failing. Test absolutely everything all fine.
Now 10 flashes. Check and swap pressure switch starts prog and heats..woohoo. Stops after heat 10 flashes. Check all and finally decide to get board from EMW.
Put in board, test going well until rinses 8 flashes WTF!!!!!!!!!!!!!
Check all again, but 8 flashes every time on fill. Check brushes as a last resort, loads on them and motor tests well. Put originals back in.
Put back old board just to verify the 13 flashes and has now sailed through every programme over two days at least twice.WTFF!!!!!!!!!
:angry4: :shake: :bang:
If you can’t picture me in the workshop last night think Tasmanian Devil in the old Bugs Bunny cartoons.
So do I presume that once I get it back to the customer it’s going to work fine…….I wouldn’t bet on it 😥
TC
Rant over. Sedation kicking in
