wd12x uk eprom, module help!
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries wd12x uk eprom, module help!
  • #32520
    dna
    Hi, i am trying to order the module for this model as the element was faulty, i have cahnged it but now the appliance just fills then drains straight away, constantly with the timer rotating through quickly. I believe the heater relay ha probably blown, the querie i have though is that whilst ordering the part it stated it did not come with the eprom??? can some one please tell me what this is? i suspect its the programming code? please help! 😉
    #235437
    franz
    Re: wd12x uk eprom, module help!
    Basically its a micro chip with the model number and relevant programmes on it – you will have to order one and fit it in the receptacle on the module
    #235438
    dna,
    from begining you should read how many times power-led flashing in order to read error… just afterwards in case you cannot manage dealing the problem (and you are sure about that PCB is out) you can order new PCB.
    You can use old eprom in the case it isn’t broken… just unsolder and fit in new place (be aware of mark key/position when feet it back)…
    #235439
    dna
    THANKS VERY MUCH GUYS!!!
    #235440
    alro
    dna
    just tell EMW model number and they will send you a recon board with 12 months guarentee phone number 0115952118
    cheers alro
