WD12XUK F13 Fault Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › WD12XUK F13 Fault This topic has 6 replies, 4 voices, and was last updated 18 years, 3 months ago by iadom. Viewing 7 posts - 1 through 7 (of 7 total) Author Posts January 9, 2008 at 4:27 pm #33545 iadomModerator Went out to this today. F13 Dryer NTC or jammed fan motor, fault intermittant. NTC appears to be OK. Fan motor with metal fan is fine. Is it still likely to be an NTC fault or possible poor module contacts? Jim. January 9, 2008 at 6:10 pm #239121 helo_75Participant well nearly everyone ive done has been the ntc if im honest does it flash f13 even if you put it on wash? January 9, 2008 at 8:56 pm #239122 Penguin45Participant Re: WD12XUK F13 Fault Had a few with the wiring broken inside the insulation at the NTC. Chris. January 9, 2008 at 10:25 pm #239123 iadomModerator Re: WD12XUK F13 Fault I had it running for 20 minutes, tugged the wiring to NTC ( this one has AMP tags) but it worked perfectly. I may try a new NTC, they are cheap so I will at least be proactive. Jim. January 9, 2008 at 10:38 pm #239124 Simon46Participant Re: WD12XUK F13 Fault I took one out put it back it worked, so intermittent they can be. S. January 9, 2008 at 10:43 pm #239125 iadomModerator Re: WD12XUK F13 Fault Thanks for that Simon, or should that be Yoda. 😆 January 9, 2008 at 10:49 pm #239126 Simon46Participant Re: WD12XUK F13 Fault Hehe S. Author Posts Viewing 7 posts - 1 through 7 (of 7 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
