wd420 33141231
  • #25081
    timdowning
    ‘extra rinse’ light on all the time. And when any cycle is started the cycle runs for a few minutes then stops.
    any ideas????
    thanks.
    #204434
    phil59
    Re: wd420 33141231
    f01 light 4, motor triac
    f02 light 3 motor, jammed/ tacho
    f03 lights 3&4 Ntc fault
    f04 light 2. pressure sw stuck on empty
    f05 lights 2&4, pressure sw stuck on full
    f06 lights 2&3, N/A?
    f07 lights 2&3&4 heater relay
    f08 light 1. heater relay
    f09 lights 1&4 eprom/setup error
    f10 lights 1&3, pressure switch not sensing
    f11 lights 1&3&4, pump/draining error
    f12 lights 1&2, communication error
    f13 lights 1&2&4, dryer ntc/ fan motor
    f14 lights 1&2&3, dryer heater
    f15 lights 1&2&3&4, dryer heater relay
    f16 N/A
    f17 light 4, door lock
    f18 light 3 comms error (3 phase motor) power board
    f1 and f17 share the same light
    #204435
    funkyboogy
    Re: wd420 33141231
    most probsly the module….
    usual pieces of cr$p….
    you will need module and eprom as orig soldered in…
    ally
