wd420 Arrrgghhh!
  • #45515
    neilsukwg
    Changed the power module last week.
    Machine was dead.
    New problem apeared after 2 washes.
    Crease Guard light flashing with on/off.
    UKWG fault guide F02 indicates pressure s/w stuck on empty, ordered and fitted switch, still got same problem.
    Have checked motor, heater and dryer element for low insulation. Squeezed all edge connectors including ntc.
    Help! 😕
    #285959
    johnnyj
    Re: wd420 Arrrgghhh!
    F02 is a motor fault, probl’y wiring harness or something along that line JJ
    #285960
    neilsukwg
    Sorry my mistake, should have got book out of van.
    Actual fault is F04 Light 2.. Pressure switch stuck on empty
    #285961
    franz
    check pressure vessel for blockage – had 1 last week blocked with detergent
    Franz
