Have customer with Hotpoint WD420 cold fill. With only very small load customer complains it takes 2/3 hours on drying cycle then clothes still hot & moist, no lights flashing. Called in did quick check but have not had much to do with this model. can anyone help guide me on this please. Does machine have component or test programme. Regards clayside
You need to take the heater box of the top of drum and I think you’ll find the cause of problem….Fluff (9 times out of 10) also check to make sure the cold valve is letting water thru…
