wd420 hpt
  • #33569
    dopper
    got a hpt wd420 there was a code which meant the stat on the dryer unit had gone, so changed that, but when i put it on a wash the dryer elements heat up and so blow that stat, anyone know why the dryer element would be coming on,no earth faults?
    paul
    #239216
    Re: wd420 hpt
    Relay on PCB faulty.?????
    Just a guess.
    dopper
    Re: wd420 hpt
    have put a pcb on from emw?
    #239218
    Re: wd420 hpt
    Have you got a wiring diagram, I can probably fish one out for you if you think it might help.
    helo_75
    does it have a 4 way valve and a mesh filter on the back of the heater box?
    #239220
    robbo1973
    Re: wd420 hpt
    i had this before and i had got 2 connectors round the wrong way when refitting new board 😳 . instead of heater on it put dryer heater on while on wash.
    #239221
    helo_75
    yes, good call
    if you look on the pcb, the wash heater connections fit with the pressure switch
    thats how u know
    email me if u want the service maual
    helo_75@hotmail.co.uk
    #239222
    dopper
    Re: wd420 hpt
    if anyone has the wiring diagram for board can you send it please.
    paul
    #239223
    dopper
    Re: wd420 hpt
    swaped them wires round think they would make them different colours, jnoted wires down when i changed pcb did not see they where same colour will have to watch for that next time, thanks for help
